My Wyze Cam v4 won't turn on.
Problem
The status light does not light up or the device is not turning on.
Troubleshooting
  1. Ensure you are using the provided power cable and adapter that came with the camera.
    1. If you are using the provided power cable and adapter, try another power cable and adapter, if possible.
  2. Verify that you are connecting the power cable correctly to the camera.
    1. Wyze Cam v4’s microUSB slot is on the back of the camera.
    2. The male microUSB side should be inserted into the camera and the male full-size USB side should be inserted into the adapter.
  3. Plug the camera into a different power outlet.
  4. Press and hold the setup button to see if you hear “ready to connect”.
  5. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
      1. If you have one installed, you must remove the microSD card before resetting your Wyze Cam v4.
    2. Ensure the camera is plugged into power.
    3. Pull the base away from the bottom of the camera. The next step will reset your device.
    4. With the camera powered on, press and hold the SETUP button on the bottom of the camera for 10 seconds.
      1. Single-pressing the SETUP button will not reset your Wyze Cam v4. You must press and hold the SETUP button for 10 seconds, until the status light turns red, to reset the device.
    5. Once the status light starts flashing red, the camera is fully reset.
  6. If the camera still does not power on, try another power cable or adapter to see if the cable or adapter is defective.
