The spotlight on my Wyze Cam v4 isn't turning on when motion is detected.
Problem
Wyze Cam v4’s built-in spotlight does not turn on when motion is detected.
Troubleshooting
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. Check that your Wyze Cam v4’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Toggle the spotlight on/off to check that it's working.
    1. In the Wyze app, tap on your camera.
    2. After the live stream loads, tap the spotlight icon.
  4. Ensure the camera is set to detect motion.
    1. In the camera’s settings, tap Event Recording.
    2. Enable Motion then select All Events.
    3. Tap Customize Detections.
    4. Next to Other Motion, ensure that the boxes are checked for both the Tag and Notify columns.
    5. Attempt to trigger the camera by creating movement in front of the device.
  5. Verify that the camera’s built-in spotlight is set to turn on when motion is detected.
    1. In the camera’s settings, tap Spotlight Settings.
    2. Enable Motion then select All Motion.
  6. Adjust the Detection Settings.
    1. In the camera’s settings, tap Detection Settings.
    2. Under Motion Detection Sensitivity, adjust the slider bar to High.
    3. Tap Detection Zone and toggle it off while testing.
  7. Check that there are no Automations set up that would interfere with your other settings.
    1. On the Home tab of the Wyze app, tap the Automations tab to check.
    2. We recommend disabling your other automations and adding them back one by one while troubleshooting.
  8. Power cycle the camera by unplugging it from its power source for 5 seconds and then plugging it back in.
  9. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
      1. If you have one installed, you must remove the microSD card before resetting your Wyze Cam v4.
    2. Ensure the camera is plugged into power and powered on.
    3. Pull the base away from the bottom of the camera. The next step will reset your device.
    4. With the camera powered on, press and hold the SETUP button on the bottom of the camera for 10 seconds.
      1. Single-pressing the SETUP button will not reset your Wyze Cam v4. You must press and hold the SETUP button for 10 seconds, until the status light turns red, to reset the device.
    5. Once the status light starts flashing red, the camera is fully reset.
  10. Once the camera is set back up, enable the spotlight by going to the camera’s settings > Spotlight Settings.
