Introducing Wyze Floodlight Cam Plug-In Mount
Easily install your floodlight without a junction box.
Wyze Floodlight Cam Plug-In Mount is a solution to one of the most common limits to installing a Wyze Cam Floodlight device - not having a junction box. And if you don't have one, installation by a licensed electrician can cost upwards of $650 😱.
Here's where Wyze Floodlight Cam Plug-In Mount comes in. All you need is a GFCI outlet outside, and you can install any Wyze Cam Floodlight outside - no junction box needed.
Features we know you've been waiting for:
  • Easy plug-n-play floodlight solution. Installing a Wyze Cam Floodlight is now easier than ever. Just attach it to the mounting bracket, and plug it into any outdoor-rated outlet.
  • No junction box needed. You won't need to hire an electrician or cut holes into your house. Win!
  • Compatible with all Wyze Cam Floodlight models. It's a flexible, future-proof solution that works with Wyze Cam Floodlight v1/v2 and Wyze Cam Floodlight Pro.
  • 20 ft outdoor-rated power cord. The heavy-duty cord is weather-resistant and durable for reliable performance, even in extreme weather conditions.
  • Streamlined & consistent design. The plug-in mount comes in black and white, to match any Wyze Cam Floodlight model seamlessly.
