Is the 2-prong plug for the plug-in mount safe for outdoor use as well?
Yes, the plug for Wyze Cam Floodlight Plug-In Mount is safe for outdoor use as long as it is connected to a GFCI outdoor power outlet with a power output of 110-120V AC.
  • Compliance: UL62, UL817, UL2556, UL 1581, 48 hour salt spray, 105º temp rating.
  • Power cord rating: SJTW (Hard service, thermoplastic cable, S: service, J: junior, T: thermoplastic, W: weather-approved).
Also, in accordance with UL153 certification requirements, Wyze Cam Floodlight devices do not require grounding because they have insulated exteriors without metal surfaces, and are low-power devices.
