Wyze Floodlight Cam Plug-In Mount Troubleshooting
Power Issues
Problem
Your Wyze Floodlight Cam Plug-in Mount won’t power on your Wyze Cam Floodlight.
Troubleshooting
  1. Remove the device from power.
  2. If possible, verify if the power outlet has a normal power supply of 110-120V AC.
  3. Ensure the devices are not visibly damaged.
  4. Try a different outlet.
  5. Ensure that Wyze Floodlight Cam Plug-in Mount was installed properly by following the steps in our Wyze Floodlight Cam Plug-in Mount Installation Guide.
    • If you’re ever unsure when dealing with wiring or power, we recommend reaching out to a licensed electrician at your discretion.
  6. If possible, try a different Wyze Floodlight Cam Plug-in Mount.
  7. If possible, try a different Wyze Cam Floodlight.
  8. If possible, try wiring Wyze Cam Floodlight to a junction box.
Other Issues
For all other troubleshooting, please follow the troubleshooting provided for the attached Wyze Cam Floodlight.
