Wyze Cam Floodlight Plug-In Mount requires a power input of 110-120V AC, and a GFCI protected outlet. This is standard for most residential homes in the US.
- Introducing Wyze Floodlight Cam Plug-In Mount
- Wyze Floodlight Cam Plug-In Mount Installation Guide
- Wyze Floodlight Cam Plug-In Mount Quick Start Guide
- Wyze Floodlight Cam Plug-In Mount Troubleshooting
- What is Wyze Floodlight Cam Plug-In Mount?
- How long does it take to install the plug-in mount?
- Should I connect the plug-in mount to a power source before installing the floodlight camera?
- What are the power input requirements for the plug-in mount?
- Is the 2-prong plug for the plug-in mount safe for outdoor use as well?
- Is Wyze Floodlight Cam Plug-In Mount weather-resistant?
- See more
