Many Wyze Cam devices can be firmware flashed, which erases and replaces the firmware on the camera. This can help fix critical bugs, and force updates if necessary.
Firmware flashing is not considered a standard troubleshooting step, however. It requires additional knowledge and devices, including a microSD card, microSD card adapter, and a computer with an SD card slot.
Note: We recommend using a 32 GB microSD card in format FAT32 for firmware flashing.
Select your Wyze Cam from the list below for firmware flashing instructions:
To firmware flash your Wyze Cam v4:
- Insert your microSD card into the computer and ensure it does not have any other files on it.
- Download the desired version of firmware from the Release Notes & Firmware page.
- Unzip/open the .zip file.
- Ensure the unzipped file is named “recovery_wcv4.bin”.
- If not, rename it.
- Drag the file to the root directory of the microSD card and then remove the card from the computer.
- Power off the camera by unplugging it from the wall or power adapter.
- Insert the microSD card into Wyze Cam v4, then press and hold the setup button on the camera while plugging the camera back into the wall. Be sure to keep holding the setup button for 3-6 seconds before releasing it.
- The camera will automatically begin the firmware flash process. This may take up to 5 minutes to complete.
- The status light will appear solid purple as both the red and blue lights will be on at the same time.
- Once the flash is complete, the status light will become solid blue and the camera will reboot itself.
- If the camera was already set up in the Wyze app, it should automatically reconnect.
- If the camera was not set up in the Wyze app, walk through setting it up like new.
- Remove the microSD card from the camera before continuing use.
- To continue using the microSD card, reinsert it into the computer and remove the “recovery_wcv4.bin” file before reinserting it into the camera.
To firmware flash your Wyze Cam v3 Pro:
- Ensure the unzipped folder is named “recovery_wcv3p.bin”.
- Power off the camera by unplugging it from the wall.
- Insert the microSD card into Wyze Cam v3, then press and hold the setup button on the camera while plugging the camera back into the wall. Be sure to keep holding the setup button for 3-6 seconds before releasing it.
- If the card remains inserted, the camera will attempt to firmware flash every time it reboots.
- To continue using the microSD card, reinsert it into the computer and remove the “recovery_wcv3p.bin” file before reinserting it into the camera.
To firmware flash your Wyze Cam v3:
- Ensure the unzipped folder is named “demo_wcv3.bin”.
- To continue using the microSD card, reinsert it into the computer and remove the “demo_wcv3.bin” file before reinserting it into the camera.
To firmware flash your Wyze Cam v2:
- Ensure the unzipped folder is named “demo.bin”.
- Insert the microSD card into Wyze Cam v2, then press and hold the setup button on the camera while plugging the camera back into the wall. Be sure to keep holding the setup button for 3-6 seconds before releasing it.
- The status light will have both the yellow and blue lights on at the same time.
- Once the flash is complete, the status light will become flashing yellow and the camera will reboot itself.
- To continue using the microSD card, reinsert it into the computer and remove the “demo.bin” file before reinserting it into the camera.
To firmware flash your Wyze Cam v1:
- Ensure the unzipped folder is named “FIRMWARE_660R_F.bin”.
- Insert the microSD card into Wyze Cam v1, then press and hold the setup button on the camera while plugging the camera back into the wall. Be sure to keep holding the setup button for 12-15 seconds before releasing it.
- The status light will change during this same time.
- If the camera was not set up on the Wyze app, walk through setting it up like new.
- To continue using the microSD card, reinsert it into the computer and remove the “FIRMWARE_660R_F.bin” file before reinserting it into the camera.
To firmware flash your Wyze Bulb Cam:
- Ensure the unzipped folder is named “recovery_bc.bin”.
- Turn off power to your bulb cam at the switch.
Insert the microSD card into Wyze Bulb Cam, then flip the switch to turn on power to the bulb. The camera will automatically begin the firmware flash process. This may take up to 2-3 minutes to complete.
The status light will blink purple.
Once the flash is complete, the status light will flash red, then alternate between red and blue, before turning solid blue.
- To continue using the microSD card, reinsert it into the computer and remove the “recovery_bc.bin” file before reinserting it into the camera.
To firmware flash your Wyze Window Cam:
- Ensure the unzipped file is named “og_otp_wc.bin”.
- Power off the camera by unplugging it from the power outlet.
- Insert the microSD card into Window Cam, then plug the camera back into the outlet.
- The camera will automatically begin the firmware flash process. This may take up to 2-3 minutes to complete.
- The status light will flash red and blue.
- If the camera has not been set up in the Wyze app, set it up like new.
- To continue using the microSD card, format the card to remove the file. Go to your camera's Settings > microSD Card and tap Format.
To firmware flash your Wyze Solar Cam Pan:
- Ensure the unzipped folder is named “G0K5G1TS”.
Insert the microSD card into Wyze Solar Cam Pan, then manually wake up the camera by connecting to the live stream or triggering the PIR motion detection. The camera will automatically begin the firmware flash process. This may take up to 5 minutes to complete.
The status light will appear red at this time.
- Once the flash is complete, the status light will flash alternating between red and blue, play a confirmation tone, and begin motor calibration.
To firmware flash your Wyze Duo Cam Pan:
- Ensure the unzipped folder is named “FW98566A.bin”.
Insert the microSD card into Wyze Duo Cam Pan, then plug the camera back into the wall. The camera will automatically begin the firmware flash process. This may take up to 5 minutes to complete.
- Once the flash is complete, the status light will flash, alternating between red and blue, and announce “firmware upgraded successfully.”
- To continue using the microSD card, reinsert it into the computer and remove the “FW98566A.bin” file before reinserting it into the camera.
To firmware flash your Wyze Cam Pan v4:
- Unzip/open the .zip file and locate the .bin file.
- Ensure the .bin folder is named “recovery_wcpanv4.bin”.
- Drag the recovery_wcpanv4.bin file to the root directory of the microSD card and then remove the card from the computer.
- Insert the microSD card into Wyze Cam Pan v4, then press and hold the setup button (do not release) on the camera while plugging the camera back into the outlet. Keep holding the setup button until the status light turns solid purple (the red and blue lights will be on at the same time). Continue holding for 3-6 seconds before releasing it.
- The camera will automatically begin the firmware flash process. This may take up to 3 minutes to complete.
- To continue using the microSD card, reinsert it into the computer and remove the “recovery_wcpanv4.bin” file before reinserting it into the camera.
To firmware flash your Wyze Cam Pan v3:
- Ensure the unzipped folder is named “recovery_wyzepan3.bin”.
- Insert the microSD card into Wyze Cam Pan v3, then press and hold the setup button on the camera while plugging the camera back into the wall. Be sure to keep holding the setup button for 3-6 seconds before releasing it.
- To continue using the microSD card, reinsert it into the computer and remove the “recovery_wyzepan3.bin” file before reinserting it into the camera.
To firmware flash your Wyze Cam Pan v2:
- Ensure the unzipped folder is named “recovery_wcpv2.bin”.
- Insert the microSD card into Wyze Cam Pan v2, then press and hold the setup button on the camera while plugging the camera back into the wall. Be sure to keep holding the setup button for 3-6 seconds before releasing it.
- To continue using the microSD card, reinsert it into the computer and remove the “recovery_wcpv2.bin” file before reinserting it into the camera.
To firmware flash your Wyze Cam Pan v1:
- Insert the microSD card into Wyze Cam Pan v1, then press and hold the setup button on the camera while plugging the camera back into the wall. Be sure to keep holding the setup button for 3-6 seconds before releasing it.
To firmware flash your Wyze Duo Cam Doorbell:
Insert the microSD card into Wyze Duo Cam Doorbell, install the battery pack then press the doorbell button to wake it up. The doorbell will automatically begin the firmware flash process. This may take up to 5 minutes to complete.
- The status light will flash blue during this time.
- Once the flash is complete, the doorbell will announce " firmware upgraded successfully."
- If the doorbell was already set up in the Wyze app, it should automatically reconnect.
- If the doorbell was not set up in the Wyze app, walk through setting it up like new.
- To continue using the microSD card, reinsert it into the computer and remove the “FW98566A.bin” file before reinserting it into the doorbell.
To firmware flash your Wyze Cam Outdoor v1/v2:
- Ensure the unzipped folder is named “sd_update”.
- Power off the camera by flipping the power switch to the off position.
- Insert the microSD card into Wyze Cam Outdoor v1/v2, then flip the power switch back to the on position.
- You may need to power cycle the camera after removing the microSD card by flipping the power switch to the off position for 5 seconds and then flipping it back to the on position.
- To continue using the microSD card, reinsert it into the computer and remove the “sd_update” file before reinserting it into the camera.
To firmware flash your Wyze Base Station:
- Power off the base station by unplugging it from the wall.
- Insert the microSD card into Wyze Base Station, then plug it back into power.
- The base station will automatically begin the firmware flash process. This may take up to 5 minutes to complete.
- The status light may either stay solid yellow or begin blinking blue.
- Once the flash is complete, the status light will become solid blue and the base station will reboot itself.
- If the base station was already set up in the Wyze app, it should automatically reconnect.
- If the base station was not set up in the Wyze app, walk through setting it up like new.
- Remove the microSD card from the base station before continuing use.
- If the card remains inserted, the base station will attempt to firmware flash every time it reboots.
- To continue using the microSD card, reinsert it into the computer and remove the “sd_update” file before reinserting it into the base station.
Additional Notes:
- For all other Wyze Cam devices not listed here, firmware flashing is not a necessary troubleshooting step.
