Wyze devices can be paired with voice assistants such as Google Assistant and Alexa. Once you set up the integration, you can use voice commands to affect Wyze Cam and Wyze Bulb. Here is a list of voice commands that work with Wyze products:
Alexa Voice Commands
Wyze Cam:
- “Alexa, show me [camera name].”
- “Alexa, show my [camera name].”
- “Alexa, show the [camera name].”
- “Alexa, show [camera name].”
Click here to learn more about Wyze Cam and Alexa integration.
Wyze Bulb:
- "Alexa, turn (bulb name) off."
- "Alexa, turn (bulb name) on."
- "Alexa, set the (bulb name) to (percentage of brightness)."
- "Alexa, set (bulb name) softer."
- "Alexa, make the (bulb name) warmer."
- "Alexa, set the (bulb name) cooler."
- "Alexa, make the (bulb name) whiter."
- "Alexa, make the (bulb name) warm white."
- "Alexa, set the (bulb name) to daylight."
Here is a list of words you can use to change a bulb to a specific color temperature in kelvin value.
Shade of White | Color Temperature in Kelvin Value |
warm, warm white | 2200 |
incandescent, soft white | 2700 |
white | 4000 |
daylight, daylight white | 5500 |
cool, cool white | 7000 |
Click here to learn more about Wyze Bulb and Alexa integration.
Google Assistant Voice Commands
Wyze Cam:
- “OK Google, show me [camera name] on [casting device name].”
- “OK Google, show my [camera name] on [casting device name].”
- “OK Google, show the [camera name] on [casting device name].”
- “OK Google, show [camera name] on [casting device name].”
Click here to learn more about Wyze Cam and Google integration.
Wyze Bulb:
- "Hey Google, Turn on <bulb name>."
- "Hey Google, Turn Off <bulb name>."
- "Hey Google, Brighten the <bulb name>"
- "Hey Google, Set <bulb name> to 50%" (scale of 1-100%)
- "Hey Google, "Dim/Brighten <bulb name> by 50%" (scale of 1-100%)
- "Hey Google, set (bulb name) to Ivory."
- "Hey Google, set (bulb name) to Cool White."
You can use use the color temperature commands (from warmest to coolest): Candlelight, Incandescent, Warm White, Cool White, Daylight, and Ivory.
