Voice Commands for Wyze Devices
Wyze devices can be paired with voice assistants such as Google Assistant and Alexa. Once you link your Wyze account to Alexa or Google Assistant, you can use voice commands to control your Wyze devices. Here is a list of voice commands that work with Wyze products.
👉 To use with Google Assistant, say "OK Google" or "Hey Google" instead of "Alexa."
Alexa Voice Commands for Wyze Cam
To view and hide the camera’s Live stream, say:
  • “Alexa, show me [camera name].”
  • “Alexa, show my [camera name].”
  • “Alexa, show the [camera name].”
  • “Alexa, show [camera name].”
To stop viewing your camera’s Live Stream, say:
  • “Alexa, stop.”
  • “Alexa, go home.”
Notes:
  • The Wyze skill does not work with Wyze Cam v1.
  • Camera-related commands only work with Amazon Echo devices with screens.
  • The Wyze skill does not support 2-Way Audio or pan/tilt/zoom capabilities.
  • The camera’s Live stream will be displayed on your Amazon device for 10 minutes before it automatically turns off. To continue streaming, repeat the voice command.
  • If your camera is turned off, Alexa won’t be able to access the Live stream.
Alexa Voice Commands for Wyze Bulb and Wyze Bulb Color:
To turn your Wyze Bulb on/off with Alexa, say:
  • "Alexa, turn (bulb name) off."
  • "Alexa, turn (bulb name) on."
To adjust the brightness, say:
  • "Alexa, set the (bulb name) to (0-100%)."
To adjust the color temperature, say:
  • "Alexa, set (bulb name) softer."
  • "Alexa, make the (bulb name) warmer."
  • "Alexa, set the (bulb name) cooler."
  • "Alexa, make the (bulb name) whiter."
  • "Alexa, make the (bulb name) warm white."
  • "Alexa, set the (bulb name) to daylight."
To adjust the color, say:
  • "Alexa, make the (bulb name) (color)."
    • Example: Alexa, make (bulb name) pink.
Here is a list of words you can use to change a bulb to a specific color temperature or color (Wyze Bulb Color only).
Shades of White Colors for Wyze Bulb Color (Try these!)
warm, warm white red, tomato, crimson, pink, magenta
incandescent, soft white orange, chocolate, peach, salmon
white yellow, gold, lime, olive
daylight, daylight white green, aquamarine, forest green, lawn green
cool, cool white blue, teal, purple, fuchsia, orchid
Alexa Voice Commands for Wyze Plug
To turn your Wyze Plug on/off with Alexa, say:
  • "Alexa, turn (plug name) off."
  • "Alexa, turn (plug name) on."
Alexa Voice Commands for Wyze Lock
To check your Wyze Lock's door status*, say:
  • "Alexa, check the status of (door name)."
  • "Alexa, status of (door name)."
* Door status: Locked or unlocked.
To unlock your Wyze Lock, say:
  • "Alexa, unlock (door name)."
To lock your Wyze Lock, say:
  • "Alexa, lock (door name)."
Note: Wyze Lock Bolt is not compatible with Alexa as it is Bluetooth-only.
Alexa Voice Commands for Wyze Sense
To turn your Wyze Sense on/off with Alexa, say:
  • "Alexa, turn (Sense name) off."
  • "Alexa, turn (Sense name) on."
Alexa Voice Commands for Wyze Air Purifier:
To turn your air purifier on or off, say:
  • "Alexa, turn on/off my (air purifier name)"
To change air purifier modes, say:
  • "Alexa, set (air purifier name) to Auto/Sleep Mode"
To set the air purifier speed, say:
  • "Alexa, set (air purifier name) to Low / Medium / Max / Turbo"*
* Note: Do not include the word "Speed" in your command as it is not recognized as part of the command. Also, "increase/decrease speed" is not an available command.
Google Assistant Voice Commands
Check the lists above for more voice commands, which are interchangeable with Alexa.
Wyze Cam:
  • “OK Google, show me [camera name] on [casting device name].”
  • “OK Google, show my [camera name] on [casting device name].”
  • “OK Google, show the [camera name] on [casting device name].”
  • “OK Google, show [camera name] on [casting device name].”
Click here to learn more about Wyze Cam and Google integration.
Wyze Bulb:
  • "Hey Google, Turn on <bulb name>."
  • "Hey Google, Turn Off <bulb name>."
  • "Hey Google, Brighten the <bulb name>"
  • "Hey Google, Set <bulb name> to 50%" (scale of 1-100%)
  • "Hey Google, "Dim/Brighten <bulb name> by 50%" (scale of 1-100%)
  • "Hey Google, set (bulb name) to Ivory."
  • "Hey Google, set (bulb name) to Cool White."
You can use use the color temperature commands (from warmest to coolest): Candlelight,  Incandescent, Warm White, Cool White, Daylight, and Ivory.
Click here to learn more about Wyze Bulb and Google integration.
