Wyze Lock Compatibility Guide
What hardware is compatible with my lock?
Wyze Lock works with most single-cylinder deadbolts (that is, there is a thumb-turn style lever instead of a keyhole on the inside of the door).
Example of a single-cylinder deadbolt
Note: The hole to hold your deadbolt's tailpiece passes through the body of the Wyze Lock. Tailpieces that extend farther out are compatible as long as the brand and type of deadbolt are supported.
What brands are compatible with my lock?
Wyze Lock is compatible with the following brands of deadbolt hardware:
  • Arrow
  • Ashley Norton
  • Baldwin (not compatible with low-profile versions)
  • Callan
  • Defiant (with additional adapter)
  • Delaney
  • Emtek
  • EZ Set
  • Faultless
  • Gatehouse
  • Global Door Controls
  • Grandeur
  • Hager
  • Kwikset (not compatible with low-profile versions)
  • Max Grade
  • Omnia Industries
  • Schlage
  • Stanley
  • Toledo Fine Locks
  • Weiser (not compatible with low-profile versions)
  • Weslock
  • Yale
Wyze Lock is not compatible with the following deadbolts:
  • Medeco
  • Mortise
  • Integrated Lock & Handles
  • Rim Cylinder
WiFi Compatibility
Similar to other Wyze products, the Wyze Lock Gateway needs to be set up with a 2.4GHz network running a minimum of WPA or WPA2 security. 5GHz networks, WEP encrypted networks, and Enterprise-level encryption networks are not supported.
Still need help?
