During setup, Wyze Lock calibrates to recognize when your door is open, ajar, or closed. This works by using a sensor in the lock to determine its position relative to its closed state. Outside of the setup process though, calibrating the lock can help if Auto-Lock or the Ajar Alarm aren’t working properly.
Before calibrating:
- Enable Bluetooth on your mobile device.
- Stand near the lock for the duration of the calibration.
- Skip to step 5 if you just completed the Wyze Lock Setup process.
To calibrate your Wyze Lock:
- Open the Wyze app and tap Wyze Lock.
- Tap the gear
icon to open Lock Settings. - Scroll to the bottom of settings screen and tap Calibrate.
- Close your door and manually lock the deadbolt.
- Tap Next, and wait for your Wyze Lock to chime.
- Manually unlock the deadbolt and open the door as wide as possible.
- Tap Next and wait for your Wyze Lock to chime.
- Partially close the door so it's slightly ajar, with a small gap between the door and the frame.
- Finally, close the door again and manually lock the deadbolt.
- Tap Next to complete the calibration. Wyze Lock will then unlock and lock itself twice in succession to make sure the deadbolt functions properly.
