The Lock won't turn by hand
The Lock's thumb latch has 2 positions, vertical and horizontal. Depending on which side of the door you install Wyze Lock on, the Locked vs Unlocked position will change. Since installing the Lock with the thumb latch in the wrong position is the most common reason for it refusing to turn, try removing the lock and turning it 90° before reinstalling.
