Third-Party Integrations with Wyze
Don't have the Wyze app handy? Don't sweat it. Control Wyze products with your voice by connecting them with Amazon Alexa, Google Assistant, and IFTTT.
Amazon Alexa and Google Assistant
Wyze products work with all Alexa-enabled and Google Assistant-enabled devices, including the Echo Show and the Google Home.
A few ways to use Wyze products and with Alexa and Google Assistant:
  • Ask Alexa to show the Live stream from your Wyze Cam on your Echo Show.
  • Tell Google Assistant to set the brightness on your Wyze Bulb to 50%.
  • Ask Alexa to turn on the Wyze Plug to your lamp.
Choose a link below to get started.
Amazon Alexa Setup Guide | Google Assistant Setup Guide.
IFTTT
IFTTT gives you even more control of your Wyze devices with Applets, which use triggers to execute actions.
A few examples of how you can use Wyze products and IFTTT together:
  • If you're away from home, turn your Wyze Bulbs to vacation mode.
  • If your Roomba is active, stop Wyze Motion Detection
  • If your Wyze Cam detects a smoke alarm sound, send a text message.
Follow the link below for the IFTTT Setup Guide.
