Alarms
For another layer of security, Wyze Lock can sound an alarm if it senses that the door has been left open, or if there's a door jam. You can manage these alarms in your Alarm Settings.
To control your lock's Alarm Settings:
  1. Open the Wyze app and tap Wyze Lock.
  2. Tap on the gear to open Settings, then tap Alarm Settings.
  3. Toggle the Door Jam Alarm or Left Open Alarm settings
    • Door Jam Alarm: Wyze Lock is unable to lock due to a misalignment with the door frame.
    • Left Open Alarm: Your door has been ajar for a set amount time.
      • Set the amount of time before the alarm sounds (1 minute - 60 minutes).
