Wyze Thermostat Setup Guide
Installing your Wyze Thermostat should be a quick, 30-minute process. If you've confirmed that your HVAC system is compatible using the Compatibility Checker, follow the steps below and in the video to get started.
Important: Don't feel prepared or safe to install your own thermostat? We've designed Wyze Thermostat to be easy to install, but use your own judgment. If you're in doubt, stop. Call your local HVAC technician for assistance.
To set up your Wyze Thermostat:
  2. On the Add menu, tap Device.
  3. Tap Home > Wyze Thermostat.
  4. Tap Begin Preparation.
  5. Follow along in the app, and with the video below.
    With your Wyze Thermostat installed and powered on, it's time to finish setting it up in the Wyze app!
  6. Make sure your phone/tablet’s Bluetooth is enabled.
  7. The Wyze app will automatically begin searching for and pairing with your Wyze Thermostat. Be sure to keep your phone near the thermostat.
  8. Once paired, you will be prompted to enter your Wi-Fi name and password.
  9. You’re connected! To finish up, name your new thermostat and begin customizing your settings.
Additional Notes:
  • You may have to enable Location Services on your device to use Bluetooth.
  • Wyze Thermostat is only compatible with 2.4 GHz Wi-Fi networks.
