Temperature Preferences
Keep the temperature where you want it.
Wyze Thermostat lets you customize three (3) Temperature Preferences, Home, Sleep and Away.
  • Home: When you're home and active.
  • Sleep: When you're home and asleep, or inactive.
  • Away: When you're away from home.
Consider these preferences your building blocks for building a Schedule for your thermostat. Build a schedule for your day (or week) by setting preferred temperatures for when you're home or away, and arranging the blocks as needed.
You can edit your Temperature Preference in the Wyze app. Go to your Wyze Thermostat settings, then tap Temperature Preference.
