Hands off the thermostat!
With Schedules, you can program your thermostat settings for one week, each individual day of the week, any group of days, or a few hours at a time. You can go even further to customize the temperature of a specific time period without changing any other time slots.
To create a schedule for Wyze Thermostat:
- In the Wyze app, tap on your Wyze Thermostat.
- Tap on the Settings gear on the top right.
- On the Settings screen, tap Schedule > Create schedule.
- On the Edit Schedule screen:
- Tap the day(s) you want your schedule active under Repeats.
- Create schedules for Home, Away, and Sleep under Blocks > Add block.
- If you add a Home block, that schedule will only apply when your thermostat is in Home mode.
- Tap Save to save your new block.
- Tap Save to create your schedule.
To delete a schedule for Wyze Thermostat:
- In your Wyze Thermostat Settings, tap Schedule.
- Swipe left on the schedule you want to delete, then tap the trashcan icon.
