Auto Switch
Wyze Thermostat can sense when you’re home.
With Auto Switch enabled, your Home and Away temperature status will change automatically. Using your phone’s location, along with a 3-mile geofenced range, your thermostat will switch between your Home and Away preferences whenever you enter or leave that range.
Your Wyze Thermostat also has a built in motion sensor. When this sensor detects movement in front of the thermostat while the status is Away, it will automatically switch to Home.
Auto Switch is enabled by default, but can be toggled on/off in your Wyze Thermostat settings.
