Minimum Run Time on Wyze Thermostat
Keep your HVAC system going strong with Minimum Run Time.
Wyze Thermostat uses the Minimum Run Time feature to set the minimum amount of time the system should run after you’ve turned it on, even if it’s been manually turned off. This has a default of 2 minutes.
Note: This feature is automatic and the time cannot be adjusted.
