Fahrenheit or Celsius?
By default, Wyze Thermostat is set to Fahrenheit, but you can change it to Celsius in the Wyze app.
To change your Units:
- In the Wyze app, tap on your Wyze Thermostat.
- Tap on the Settings icon
to open your Settings. - Tap Temperature Units to select ºF or ºC.
- Tap Save to confirm your changes.
