Wyze Thermostat Tech Specs
Wyze Thermostat Device Details
Color: Black, with white accents
Materials:
  • Body and back panel: PC+ABS
  • Face plate: PMMA
Dimensions:
  • Thermostat: 120mm (L) x 65mm (W) x 33mm (D)
  • Wall Cover: 16.5 mm (L) x 12.7mm (W)
Weight: <1lb
Compatibility
System Compatibility:
  • Gas, oil, electric
  • Conventional (3H/2C)
  • Heat pump (4H/2C)
Phone Compatibility:
  • Android 5.0+
  • iOS 9.0+
Display:
  • IPS Display
  • 180º Viewing angle
Power
Power source:
  • 24VAC through C terminal
  • C-wire adapter included
    • The C-wire adapter (included) enables you to power your thermostat without a C-wire.
Power consumption: <3.5VA
3-in-1 Sensor
  • Temperature & humidity
  • PIR motion
Sensor Dimensions: 80mm (L) x 40mm (W) x 16mm (D)
Communication
  • Bluetooth
  • 2.4GHz WiFi
Recommended Temperature
Operating
  • 32°F - 130°F (0°C - 55°C)
  • 5% - 95% RH (non condensing)
Storage
  • -31°F - 113°F (-35°C - 45°C)
Weather Resistance
None. Indoor use only.
Environmental Information
Certifications
FCC, IC, and California Proposition 65
Eco-Friendly
  • California Proposition 65 Approved
  • Recyclable packaging
  • Mercury free
  • Arsenic free
  • PVC free
Languages
English
Warranty
1-year
