Swap Heat and Cool
If your heating system is turning on your AC, or your AC is turning on your heating when testing the thermostat, this feature swaps the output of the wiring without having to change which terminals the wires are plugged into.
To turn on Swap Heat and Cool:
  1. In the Wyze app, tap on your Wyze Thermostat.
  2. Tap on the Settings icon SettingsGear.png  to open your Settings > Advanced Settings.
  3. Tap the toggle next to Swap Heat and Cool.
  4. Your changes will save automatically.
