Yes, you can change this in your device settings.
You want your phone's Wyze app notifications to play a different sound. Maybe you want it louder, or to play a unique sound just for Wyze.
The Wyze app does not have a specific notification sound you can change or set for Wyze notifications. Instead, you can change your default notification sounds in your phone or tablet's device settings.
To change the notification sound, swipe to close the Wyze app and go to your device's Settings app. Then go to Sounds & Haptics (iOS) or Sound & notification (Android) to change your sound preferences.
