How do I factory reset Wyze Car?
By resetting your Wyze Cam v2.
Wyze Car cannot be reset. Instead, you can factory reset your Wyze Cam v2.
To factory reset your Wyze Cam v2:
  1. Remove the camera from your Wyze Car.
  2. If you have a microSD card inserted in the camera, remove it.
  3. With the Wyze Cam plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds. This will reset the camera.
  4. Wait at least 30 seconds for the device to initiate.
    • This process can take up to 5 minutes. It's rare, but it's possible.
  5. The LED status light on the device will change from Solid Yellow to Blinking Yellow.
  6. The device is now ready to be set up again.
  7. Once set up, you must update the camera's firmware to use it as a Car Cam.
