Problem
Your Wyze Car shows offline in the Wyze Car app.
Troubleshooting
- Confirm that the Wyze Car app is up to date.
- In the Wyze Car app, tap the profile icon in the upper left-hand corner, then tap App information. The current app version will be listed beneath the Wyze Car logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that the Wyze Car app is out of date, head over to your mobile device’s app store and update the app.
- If possible, check that both the car and the camera’s firmware are on the latest firmware versions.
- You can check this in the Wyze Car app by going to the camera’s settings > Device Info.
- Tap the firmware version next to Cam Firmware Version and Car Firmware Version.
- If there are updates available for Wyze Car or the camera, please move forward with updating them.
- If the camera is currently connected to Travel Mode, try connecting the device to Wi-Fi instead.
- In the Wyze Car app, navigate to the camera’s settings.
- Select Travel Mode and tap Exit.
- Power cycle Wyze Car.
- Unplug the power bank from the car and camera, wait 30 seconds, then plug it back in.
- Factory reset Wyze Cam v2.
- Remove any microSD card inserted into the camera.
- With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid yellow.
- Once the status light starts flashing yellow, set up the camera as new.
- Reboot the Wi-Fi router.
Note: Once a camera is turned into a Car Cam, the live stream can only be viewed in the Wyze Car app.
