Understanding your Wyze Lock Bolt v2’s Status Lights
You’ll find the status lights on the front of your Wyze Lock Bolt v2. No light? Make sure all 8 AA batteries are properly inserted.
️⚡ All Wyze devices have a handy status light that helps determine what state the device is in.
Wyze Lock Bolt v2 Status Light Guide
Wyze Lock Bolt v2 Status Lights: During Setup
  • Pulsing red – The device is resetting and entering the setup stage.
  • Pulsing green with keypad flashing – Reset successful.
  • Pulsing green quickly – Waiting for Wi-Fi info.
    • Note: This also applies to the Reset Wi-Fi feature when pressing the reset button 3 times within 3 seconds.
  • Pulsing green slowly – The device is connecting to Wi-Fi, please wait.
  • Two quick green flashes with a slow “do mi so” beep – Connection successful.
Wyze Lock Bolt v2 Status Lights: During Configuration
  • Pulsing green with 3 beeps – Waiting for fingerprint input.
  • Flashing green quickly – Fingerprint enrollment successful.
  • Flashing red – Fingerprint input failed or timed out.
Wyze Lock Bolt v2 Status Lights: During Daily Use
  • Solid green – The lock was successfully locked or unlocked.
  • Solid red – The lock failed to lock or unlock.
  • Flashing red 3 times – Error.
    • Note: This may be due to 5 consecutive failed fingerprint attempts or a lock jam.
