Contactless, Secure Entry with Fingerprint
Gone are the days of fumbling for keys. Wyze Lock Bolt v2 uses a biometric fingerprint scanner to unlock the door in 0.3 seconds. Biometric data is stored locally on the device for extra security (never in the cloud).
AI Self-Learning Fingerprint Scanner
Traditional fingerprint locks use a "one-and-done" learning method. Our AI-powered self-learning scanner logs pressure, angle, and even tiny skin shifts with every scan, dynamically refining its model. The more you use it, the faster and sharper it gets.
Control from Anywhere with Wi-Fi
Control and monitor the lock status from anywhere, anytime. Customize lock notifications in the Wyze app.
Numbered Keypad with Access Codes
A bright, numbered keypad illuminates with a simple tap. Set and store up to 50 unique access codes, or create one-time guest passcodes that expire on a schedule.
Peace of Mind with Auto Lock
Forget to lock your door? No problem. An auto-lock timer takes the stress away. Simply set how long you want to delay auto-locking in the Wyze app, and after that time has passed, Wyze Lock Bolt v2 will lock the door for you.
Lock After Hours
Power outage? Lose internet? Worried your lock isn’t locked at night? Lock After Hours runs locally on the lock; no internet connection needed.
Anti-Peep Technology
Don't worry if someone's watching over your shoulder. Simply add extra digits before or after your code, and Wyze Lock Bolt v2 will still unlock.
Works with Wyze Video Doorbells
Lock and unlock directly from the livestream of your Wyze Video Doorbell without switching between devices to unlock the door for family and friends.
Mechanical Lock and Key Option
A mechanical lock and a set of physical keys is included so you can manually unlock your door the old-fashioned way.
Long Battery Life
Enjoy up to 8 months of battery life (batteries included).
Type-C Emergency Power Port
If the batteries drain while you're away, the USB-C port allows for a charge from a power bank so you can use your access code for entry.
IP53 Weather-Resistant and BHMA2 Certified
Backed by the Builders Hardware Manufacturers Association, this lock has been tested, slammed, twisted, and splashed thousands of times to make sure it can handle real life. It meets rigorous standards for security, durability, and performance. It’s not just smart, it’s strong.
Tamper & Jam Alarms
Wyze Lock Bolt v2 speaks up and sounds an alarm if it detects tampering from excessive incorrect unlock attempts or lock jams.
Smart Home Integration
Convenience and customization at your fingertips with integrations like Amazon Alexa and Google Assistant. Customize even more automations with Wyze Automations.
