Wyze Lock Bolt v2 Setup Guide
Before you setup your Wyze Lock Bolt v2:
  1. Make sure you are connected to data or Wi-Fi (this is only for the initial pairing with the Wyze app).
  2. Enable BluetoothⓇ on your mobile device.
    • If you’re on an iOS device, check that your Location Permissions are also enabled.
    • If you’re on a device using Android 12+, check that your Nearby permissions are also enabled.
    • Make sure that you are in BluetoothⓇ range for connection (16 feet or less).
To set up your Wyze Lock Bolt v2:
  2. On the Add menu, tap Device > Home > Wyze Lock Bolt v2.
  3. If you’ve already installed your Wyze Lock Bolt v2 on your door, tap Skip to skip installation.
    1. If not, tap Next to install your device.
  4. Tap Next to continue pairing to the Wyze app.
  5. Press and hold the RESET button on the lock for 8 seconds.
    • The status light will pulse red, then turn solid green. This may take up to 30 seconds.
  6. In the Wyze app, check the box next to "It played a beeping tone" then tap Next.
  7. If BluetoothⓇ hasn't already been enabled, you'll be prompted to allow BluetoothⓇ and Location access. Tap Next.
    • If BluetoothⓇ and location access have already been enabled, it will skip automatically.
  8. The app will automatically search and connect to your Wyze Lock Bolt v2.
  9. If you have a Wi-Fi network that you'd like to connect to, tap Yes.
    • If you want to connect to a different network, tap No, I Will Connect Manually.
  10. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
    • Tap the icon next to the text field to double-check your password.
  11. Your device will finish pairing automatically. Once complete, it's time to calibrate your lock.
  12. Follow along in the app to calibrate your Wyze Lock Bolt v2.
    1. Close and manually lock the door.
    2. Turn the thumb latch towards the door opening to extend the deadbolt.
    3. In the app, check the box next to "I have turned the thumb latch" then tap Next
    4. The device will now calibrate.
  13. Next, follow the in-app steps to create your Access Code and add your fingerprint.
  14. You're all set! Tap Done.
