Wyze Lock Bolt v2 Calibration Guide
You've completed the Wyze Lock Bolt v2 Setup Guide. It's now time to calibrate your lock!
To calibrate your Wyze Lock Bolt v2.
  1. Open the Wyze app and tap on your Wyze Lock Bolt v2.
  2. Tap the Settings gear, then Calibration.
    • Follow along in the Wyze app to calibrate your Wyze Lock Bolt v2.
  3. Close your door and manually lock the deadbolt.
    • Check the box next to I have turned the thumb latch.
  4. The Wyze app will display "Calibrating your device..." and the lock will calibrate automatically.
  5. Done with calibration!
Additional Notes
  • Calibrating your Wyze Lock Bolt v2 is a common troubleshooting step when other features like Auto-Lock and door ajar alarms aren't working properly.
