Introducing Wyze Lock Bolt v2
Smart Fingerprint Door Lock with Wi-Fi Connectivity.
Why we love Wyze Lock Bolt v2:
  • Fast, Secure Entry with Fingerprint Unlock. No digging around for keys, just set up your fingerprint in the Wyze app and you're good to go.
  • AI Self-Learning Fingerprint Scanner. Our AI-powered scanner logs pressure, angle, even tiny skin shifts with every scan. The more you use it, the better it gets.
  • Durable, Anti-Glare Tempered Glass. Other lock screens peel and crack over time. Wyze Lock Bolt v2 is made with scratch-resistant tempered glass that doesn't leave fingerprint smudges.
  • Mechanical Lock and Key Option. A mechanical lock and a set of physical keys is included so you can manually unlock your door the old-fashioned way.
  • Numbered Keypad with Access Codes. A bright numbered keypad protected by tempered glass illuminates with a simple tap.
  • Anti-Peep Technology. Don't worry if someone's looking over your shoulder. Anti-Peep technology lets you add extra digits before your code and Wyze Lock Bolt v2 will still unlock.
  • Long Battery Life. Enjoy up to 8 months of battery life (batteries included).
  • 20-Minute Installation. Wyze Lock Bolt installs on most US doors in about 20 minutes.
  • IP53 Weather-Resistant and BHMA2 Certified. This lock has been tested, slammed, twisted and splashed thousands of times to make sure it can handle real life.
  • Type-C Emergency Power Port. If the batteries die while you're away, the USB-C port allows for a charge from a power bank so you can enter your access code for entry.
  • Tamper and Jam Alarms. Wyze Lock Bolt v2 sounds an alarm if it detects tampering from excessive incorrect unlock attempts or lock jams.
