Before you begin setup, make sure you have completed the installation steps for your Wyze Cam Floodlight Pro.
👉 Depending on the location of your junction box, a ladder may be required.
To set up your Wyze Cam Floodlight Pro:
After completing the installation process in the Wyze app, tap Begin Setup.
- Floodlight not installed? Follow the steps listed in our Wyze Cam Floodlight Pro Installation Guide before beginning setup.Â
Make sure that the status light under the camera changes from solid red to either flashing purple or solid blue. This may take up to 2 minutes.
If the light does not turn on or update, press and hold the setup button on the back of the camera for 10 seconds to reboot.
- Check the box next to Light turned to flashing purple or solid blue then tap Next.
Wait for a voice prompt. You should hear “ready to connect”.
- If there is no voice prompt within 2 minutes, press and hold the setup button on the back of the camera for 10 seconds until the status light turns red to reboot.
- Check the box next to It said, “Ready to connect.” then tap Next.
If BluetoothⓇ hasn’t already been enabled, you’ll be prompted to allow BluetoothⓇ access. Tap OK.
- If BluetoothⓇ has already been enabled, it will skip to the next step.
Setting up multiple floodlights at once? Select the last 4 digits of the floodlights’ MAC addresses.
- The MAC address can be found on the side of the floodlight’s base.
Select your 2.4 GHz or 5 GHz Wi-Fi network and enter your network password. Tap Next.Â
- Tap the icon in the password field to display the password to ensure it was entered correctly.
- If your floodlight location is far from your router or there are multiple walls between them, we recommend selecting your 2.4 GHz Wi-Fi network.Â
- Name your Wyze Cam Floodlight Pro using the text field, or by choosing a suggestion. Tap Finish when done.
- You are all set! Your floodlight is set up and ready to go. Tap Done.
- You may have a prompt for a free trial of Cam Plus. Tap Continue.
- Set up some automations on the Things to Try* page, or tap Skip.
If you want to share your device, tap Share Device.
- If not, tap Maybe Later.
Things to Try: Tap Create or edit a device group, Share this device, Automate your device, or Skip. These are quick ways to set up a few automations before you finish setup. When you complete a task, it'll display a green checkmark âś…. You can move on from this page by tapping Skip.
