Wyze Cam Floodlight Pro Comparison Chart
Here are the biggest differences between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v1 and v2.
(Refurbished) Wyze Cam Floodlight v1 WYZEC3FL - RF - Wyze Labs, Inc.
Wyze Cam Floodlight Pro WYZECFLPBL - Wyze Labs, Inc.
Wyze Cam Floodlight v2
Camera Resolution 1080p 2K 2.5K QHD
Field of View
130°
160° 180°
Lumens 2600 lm 2800 lm 3000 lm
Floodlight Heads 2 2 3
Color Temperature 5000K 5000K 5000K
Wi-Fi Connectivity 2.4 GHz 2.4 GHz 2.4/5 GHz Dual-Band
Vision AI Light Control No With Cam Plus Subscription Yes
Motion Detection PIR PIR Vision AI
Supported Services Cam Plus, Cam Plus Lite, Cam Protect, Wyze Home Monitoring Cam Plus, Wyze Web View Cam Plus, Wyze Web View
Sirens 105dB at 4 in 105dB at 4 in 105dB at 4 in
Ambient Light No Yes Yes
Motion Warning No With Cam Plus Subscription Yes
Device Setup QR Code AP (Wi-Fi Access Point) Bluetooth ®
IR Lights 4 x 850nm, 4 x 940 nm 6 x 850nm 12 x 850nm
MicroSD card Compatibility Up to 256 GB Up to 256 GB Up to 256 GB
Power Supply Hardwired 110-120V Hardwired 110-120V Hardwired 110-120V
Integrations Amazon Alexa, Google Assistant, IFTTT
Supports Additional Cameras Up to 2 Wyze Cam v3 No No
Certifications FCC, UL, CE, IC, IP65 FCC, UL, CE, IC, IP65 FCC, UL, CE, IC, IP65
