Wyze Cam Floodlight Pro Mounting Guide
You can mount the floodlight on a ceiling/overhang or on the wall, as long as you have a junction box and neutral wire.
To position your Wyze Cam Floodlight Pro from a ceiling/overhang:
  1. Ensure you have a functional junction box in the location you plan to use your device. If you do not have an existing junction box, please contact a licensed electrician.
  2. Refer to the label on the joint arm behind the camera.
  3. Rotate the camera 180°, making sure that the E and arrows are in alignment.
    • Do not rotate the camera past this point or completely around as this may twist or break the connection line.
  1. Adjust the angle of the camera so it is parallel to the ground.
  2. Follow the standard installation process in our Wyze Cam Floodlight Pro Installation Guide.
  3. Rotate and tilt the floodlight so it points where you want it.
To position your Wyze Cam Floodlight Pro vertically from a wall:
  3. Make sure the W and arrows are in alignment.
  Tip: When Wyze Cam Floodlight Pro is mounted 10 feet above the ground, it will detect motion up to 30 feet away.
