Wyze Cam Floodlight Pro Tech Specs
Wyze Cam Floodlight Pro Device Details
  • Model: WYZECFLP
  • Color: White
  • Finish: Matte
  • Dimensions: 10.2 in x 9.1 in x 7.8 in (25.91 cm x 23.11 cm x 19.81 cm)
  • Weight: 2.9 lbs (1.32 kg)
  • Materials:
    • Body: Polycarbonate
    • Lens: Glass and plastic
Power Requirements
  • Requires an existing junction box
  • Power Supply: Hardwired 110 - 120V AC
Video
  • Resolution: 2.5K (2560*1440)
  • Field of View: 180° diagonal
  • Frame Rate
    • Daytime: 20 FPS
    • Nighttime: 15 FPS
  • Night Vision
    • Color Night Vision
    • Starlight Sensor
      • 12 850nm IR Lights
Audio
  • Microphone: Built-in, digital
  • Siren: 105 dB at 4 in
  • 2-Way Audio
  • “Hi, you are currently being recorded.” Motion Warning
Lighting
  • 3 adjustable floodlight heads
  • Floodlight Head Dimensions: 3.25 in x 3.25 in x 1 inch
  • Lumens: 3000 lm (1000 per head)
  • Light Temperature: 5000k color temperature
  • Dimmable: Yes
  • Controls: Manual, Motion-Activated Light, Ambient Light, Schedule, Wyze Automations
Alerts
  • Push notifications
Storage
  • Cloud Storage
    • Stored in the AWS Cloud
  • Local Storage
    • Supports 8 GB, 16 GB, and 32 GB microSD cards in FAT32 format
    • Supports up to 256 GB microSD cards in exFAT format
Connectivity
  • 2.4 GHz and 5 GHz Wi-Fi
  • 802.11 b/g/n 2.4 GHz or 5 GHz
  • BluetoothⓇ Low Energy (BLE)
Integrations
  • Alexa, Google Assistant, IFTTT
Supports Services
Phone Compatibility
  • Supports Android 9.0 and iOS 15.0 or later
Operating Temperature
  • -4°F - 140°F (-20°C - 60°C)
Weather Resistance
  • Indoor and outdoor (IP65)
Certifications
  • FCC, UL, CE, IC
Language
  • English
Warranty
  • 1-Year
