Using Automations with your Wyze Battery Cam Pro
To learn all about Automations, Shortcuts, Schedules and Device & Service Triggers, start with the article: Using Automations with the Wyze app.
How do Automations work with Wyze Battery Cam Pro?
Automations help control your Wyze Battery Cam Pro, making it easier to turn it on/off with a single tap in the app, have it turn on/off at a scheduled time or when triggered by another device.
  • Shortcuts run actions with a tap in the Wyze app.
  • Schedules control devices based on the time of day.
  • Device & Service Triggers connect multiple Wyze devices so one can trigger another.
  • Location Triggers control devices based on your location.
An example Shortcut with Wyze Battery Cam Pro
To create a shortcut to upload a video to the cloud with a single tap from the Home screen.
  2. On the Add menu, tap Automation > Shortcut.
  3. Add a name for the shortcut in the text box under the star icon.
    • Try "Upload a video."
  4. Tap Add Action.
    1. Tap on your Wyze Battery Cam Pro from the list.
    2. Tap Upload a short video to the cloud, then Save.
  5. When finished, tap Save.
Your shortcut will display at the top of the Automations tab. To add it to the Favorites tab, tap the star icon on the shortcut.
An example Schedule with Wyze Battery Cam Pro
To create a schedule to turn off motion detection every weekday between 6:00 PM and 6:00 AM. This comes in handy when you don't want motion-triggered notifications when you're home.
  2. On the Add menu, tap AutomationSchedule.
  3. Tap Name (Optional).
    1. Enter a name for the schedule. Try "Turn off motion detection."
    2. Tap Save.
  4. Tap Add Action, then the Wyze Battery Cam Pro you want to create a schedule for.
  5. Select Turn off motion detection, then Save.
  6. Tap Start Time.
    • Select 6:00 PM, then Save.
  7. Tap End Time (Optional).
    • Select 6:00 AM, then Save.
  8. Tap Save.
Pro Tip: You can also temporarily disable your notifications using our Snooze Notifications feature.
An example Device Trigger with Wyze Battery Cam Pro
To create a device trigger that turns on your Wyze Bulb when your Wyze Battery Cam Pro detects motion.
  2. On the Add menu, tap Automation > Device & Service Trigger.
    1. Enter a name for the schedule. Try "Turn on bulb with motion"
    2. Tap Save.
  4. Tap Device & Service Trigger.
    1. Select your Wyze Battery Cam Pro
    2. Tap Detects motion, then Save.
  5. Tap Add Action.
    1. Select your Wyze Bulb.
    2. Tap Turn on, then Save.
  6. When done, tap Save.
An example Location Trigger with Wyze Battery Cam Pro
To create a location trigger to turn on the spotlight for 1 minute on Wyze Battery Cam Pro when you arrive home.
  2. On the Add menu, tap Automation > Location Trigger.
    1. Enter a name for the trigger. Try "Turn on the spotlight when I arrive"
    2. Tap Save.
  4. Tap I arrive.
  5. Confirm the location displayed in the list.
  6. Tap Add Action.
    1. Select your Wyze Battery Cam Pro.
    2. Tap Turn on the spotlight for 1min, then Save.
  7. Optionally, tap to add a Time that this trigger is active.
  8. When done, tap Save.
  • Live Support Hours:
