Night Vision isn't working on my Wyze Video Doorbell Pro
Problem
The night vision feature on your Wyze Vide Doorbell Pro isn't working as expected. It's dark when night vision is expected to be on.
Troubleshooting
  1. Confirm your Wyze app and firmware are up to date.
    3. Compare your app and firmware version to the latest app version listed on our Release Notes & Firmware page.
      1. If you find that your Wyze app is out of date, head over to your mobile device’s app store, and update the Wyze app.
      2. If your doorbell's firmware is out of date, go to Account > Firmware Update to update your Wyze Video Doorbell Pro.
  2. Force close the Wyze app and restart it.
  3. Cycle through the Night Vision setting from the livestream.
    1. From the doorbell's livestream, go to Settings > Advanced Settings.
    2. Toggle through the AUTO, On, and Off options.
  4. Power cycle both the doorbell and chime.
    1. To power cycle:
      1. Wyze Video Doorbell Pro: Press and hold the Reset button on the back of the Video Doorbell Pro for 3-5 seconds until the user hears the “power off” voice prompt.
        1. The LED should not be on.
        2.  Press and hold the Reset button for another 3-5 seconds until you hear the “power on” voice prompt.
        3. If the doorbell is hardwired, switch the breaker off then back on to power-cycle.
      2. Wyze Chime Pro: Unplug the chime from the power outlet for 5-10 seconds, then plug it back in.
        1. The LED should start flashing red then blue, then a "Bluetooth connected" will prompt.
        2. The LED should turn solid blue once fully connected, then a "Connection completed" will prompt.
  5. Factory reset Wyze Video Doorbell Pro and Wyze Chime Pro.
    1. Send an app log from your doorbell's Settings > Wyze Support > Submit a Log.
    2. Press and hold the reset button on the side of the chime for 3-5 seconds until "reset successfully" prompts.
    3. Set up your doorbell and chime as new.
