My Wyze Scale Ultra shows incorrect body composition measurements.
Problem
Wyze Scale Ultra is showing incorrect body composition measurements.
Note: Body composition metrics (body fat %, water %, etc.) are only available for people between the ages of 10-100 years old. Children under 10 and seniors over 100 will not be able to access the body composition features. For users between ages 10-17, the body composition metrics are only for reference.
Troubleshooting
  2. If possible, check that your Wyze Scale Ultra’s firmware is up to date.
    2. If there is an update available for the scale, please move forward with updating it.
  3. Ensure you are measuring correctly.
    1. Place the scale on a hard, flat surface.
    2. Step on the scale barefoot, without your knees touching.
    3. Make sure your feet are not too dry or damp as this may result in incorrect or no measurements.
    4. Remain on the scale until the measurement is complete.
  4. Wipe the surface of the scale with a damp cloth, then try measuring again.
  5. Verify the scale is syncing with the Wyze app.
    1. Open the Wyze app and select Wyze Scale Ultra.
    2. Step on the scale to activate it.
    3. Ensure Connected displays in the app and the BluetoothⓇ symbol appears in the upper-left corner of the scale’s screen.
  6. Ensure the correct user profile is selected in the Wyze app while measuring.
  7. Verify your personal information (i.e. body type, year of birth, etc.) is correct in the Wyze app.
    1. In the Wyze app, go to Wyze Scale Ultra’s settings > Users.
    2. Ensure that Pregnancy/Weight-Only Mode is not enabled in the Wyze app.
  8. Power cycle Wyze Scale Ultra.
    1. Remove the batteries for 10 seconds, then reinstall them.
  9. Factory reset Wyze Scale Ultra.
    1. On the back of the scale, in the battery compartment, find the UNIT button.
    2. Press and hold the button for 3 seconds until the scale display shows “Clear”.
    3. Set up the scale as new.
