Wondering what that error on your Wyze Scale Ultra is all about? Here's a quick guide to each error message.
| Failed | Update Failed | ||
Network configuration failed. Please check the network and reconfigure. |
Scale update failed. Please try to update the device again. |
| Offline | Low Battery | ||
The server connection failed. Please check your network and try again. |
The batteries are low. Please replace the batteries. |
| Updating | Error | ||
Updating, please do not turn off the scale. |
The weight exceeds the upper limit on the device and cannot be displayed. |
| Calibrated | Factory Reset | ||
The scale was not zeroed out before measuring. Please wait until the device displays 0 and then measure again. |
The scale data has been cleared and reset. |
