If your camera gives you an error code, there is likely an issue with connectivity. The table below tells you what each error code means. This can help you track down why there is a connection error.
- I get "Device is offline (error code 90)" in the app.
- My Live stream is blurry when night vision is on
- My Pan cam keeps turning off randomly
- Audio and video are out of sync
- My Wyze Cam v1/v2 is not turning on when connected to power.
- Camera not connecting after firmware update
- QR code is incorrect
- How do I update my Wyze Cam firmware?
- Webcam Firmware Instructions
- Can't connect to the Live Stream
- See more
