My Pan cam keeps turning off randomly
Presents as: The Pan Cam keeps losing power or turning itself off without your turning it off.
Troubleshooting:
  • This is usually a power issue, so make sure you are using the original cord and adapter that came with your Wyze cam.
  • If you’re able to, try switching out the cord and/or adapter to see if that corrects the issue.
    • The power cable and/or adapter may be defective.
  • Try plugging your camera into a different power outlet.
  • Make sure the power cord you’re using is less than 16 feet long.
