How do I update my Wyze Cam firmware?
All firmware updates are managed in the Wyze app. Make sure you're on the latest version to have the best experience with your Wyze product.
To update your Wyze Cam firmware:
  1. In the Wyze app, tap on your Wyze Cam, then the Settings gear on the top right.
  2. Tap Device Info > Firmware Version.
    • Don't see the option to upgrade? Then your firmware is already up to date!
Looking for the Webcam firmware? Find it here.
