How can I change microphone permissions?
For Android:
  1. Go to your phone's setting and find the Wyze app settings. This is usually under 'Apps' or 'Apps & Notifications' sections.
  2. Go into the 'Permissions' section of the settings.
  3. Confirm the 'Microphone' permission is enabled.
For iOS:
  1. Open your phone's settings, scroll down until you see the Wyze app and select it.
  2. Under 'Allow Wyze to access' confirm that the 'Microphone' setting is allowed.
