Go to your device's Settings in the app, then tap Sharing.
Important: Only share your Wyze devices and services with people you know and trust.
You can manage your shared users two ways:
From the Sharing tab in the Wyze app:
- In the Wyze app, tap Account > Sharing.
From the Device Settings:
- In the Wyze app, tap on the device you'd like to share.
- Tap the Settings gear > Sharing.
You can manage shared users from both areas, but this article will focus on the Sharing page.
To add a shared user:
- Tap Share With New User.
- Enter the email address associated with the Wyze account that you’d like to share your device with then tap Next.
- If the email address you entered is not associated with a Wyze account, you will see a message saying “User <email> has not registered with Wyze yet. We will send out an email to invite once you confirm.”
- If this is not expected, tap Cancel and check the email with the other user.
- If you would still like to proceed, tap OK.
- Select the device(s) or service(s) that you’d like to share, then tap Share.
- The invite will show as “pending” on this page until it is accepted by the user you invited.
To remove a shared user:
- Tap on the user that you would like to remove.
- Tap the pencil icon in the upper right-hand corner.
- Uncheck any device(s) or service(s) you no longer wish to share with this user, then tap Update.
- If there are no device(s) or service(s) being shared with the user, they will automatically be removed from the list of shared users.
Note: Once you accept an invite, go to the Home tab of the Wyze app and tap the shared device. You will see a message indicating who shared the device with you.
