If your videos and events display the wrong time, there are a few troubleshooting steps that can be taken to resolve this.
Sync Time in Wyze App
The first step you can take is trying to re-sync the Wyze app with your local time.
- Using the Wyze app, navigate to the Home tab and select any Wyze Cam or device.
- Click the Settings icon
on the top right. - Tap the Advanced Settings.
- Press the Sync Time tab to cause your Wyze Cam to adjust its timestamp to the time on your phone or tablet.
Update Mobile Device's Date and Time
Check to see if your mobile device is set to automatically update your Date and Time. Follow the steps below for iOS and Android.
Update Date & Time on Your iOS Device
- From your home screen, navigate to Settings.
- Tap General.
- Tap Date & Time.
- Make sure that the option Set Automatically is turned on.
For additional information, visit Apple Support.
Update Date & Time on Your Android Device
- Tap Settings to open the Settings menu.
- Tap Date & Time.
- Tap Automatic.
