Introducing Wyze Palm Lock
The key is the palm of your hand.
The future is right now. Enter your home quickly and securely with just your palm.
Why we love Wyze Palm Lock:
  • Contactless Entry with Palm Vein Recognition. Wyze Palm Lock uses a highly secure, contactless biometric technology that identifies you by the unique pattern of veins beneath the surface of your palm. Just hold your palm in front of the lock screen, and voilà, the door unlocks!
  • Numbered Keypad (+ Anti-Peep). Use an access code to get in, and even create unique codes for everyone. With Anti-Peep, you add extra numbers before and after the code and still unlock.
  • Dual Battery System. Wyze Palm Lock comes with two batteries - a removable Main Battery with up to 6 months of battery life, and a backup battery that keeps the lock running for up to 2 weeks while the Main Battery is being charged.
  • Smart Battery Saver. Wyze Palm Lock is equipped with a millimeter Wave (mmWave) radar, the same used in self-driving cars. It scans for the presence of a person (not just movement) and only wakes up the lock when a person is detected.
  • Peace of Mind with Auto Lock. A built-in gyroscope detects the angle and movement of the door in real time. Once the door is fully closed, the lock automatically locks.
  • Manual Lock and Key Option. A set of physical keys is included with the lock so you can manually lock and unlock your door the old fashioned way.
  • Works with Wyze Video Doorbells. Lock and unlock directly from your livestream of your Wyze video doorbell, no need to switch between devices.
  • Emergency USB-C Charging. If you forget to charge the Main Battery, do an brief charge to enter your access code.
  • IP53 Weather-Resistant and BHMA3 Certified. Backed by the Builders Hardware Manufacturers Association, Wyze Palm Lock has been tested, slammed, twisted and splashed thousands of times to make sure it can handle real life.
  • Wi-Fi Connectivity. Control and monitor the lock status from anywhere, anytime.
Important Note: Wyze Palm Lock is not compatible with storm doors, as this can greatly impact battery life. If installed with a storm door, we highly recommend that you enable Extreme Battery Saving Mode.
