Wyze Palm Lock Tech Specs
Wyze Palm Lock Device Details
Color: Black
Finish: Matte
Materials:
- Frame: Aluminum Alloy and Steel
- Panel: Tempered Glass
Weight: 4 lbs (64 oz)
Dimensions:
External Assembly: 6.14 in x 2.89 in x 1.28 in (156 mm x 73.5 mm x 32.5 mm)
Internal Assembly: 7.16 in x 2.93 in x 1.18 in (182 mm x 74.5 mm x 30 mm)
Power
Power Source: Wyze Removable Battery Pack, Backup Battery
Battery Life:
  • Main Battery: Up to 6 months with normal use (10-20 luck/unlock events per day)
  • Backup Battery: Up to 1-2 weeks
Emergency Power: USB-C port (USB-C cable not included)
Connectivity
Communication Method: Bluetooth 5.0, 2.4 GHz Wi-Fi, Wi-Fi 6
Compatibility: Wyze app 3.7+, Android 10.0+ or iOS 16.0+
Door Compatibility
Compatible with most standard US doors. Replaces existing single-cylinder deadbolt.
Temperature
  • Operating Temperature: -4°F - 122°F (-20°C - 50°C)
  • Storage Temperature: -40°F - 176°F (-40°C - 80°C)
Weather Resistance
Indoor and outdoor (IP53)
Warranty
1-Year
