To set up Wyze Palm Lock:
- In the Wyze app, tap Home, then tap the plus sign + in the top right-hand corner.
- On the Add screen, tap Device.
- Tap Home > Wyze Palm Lock.
- If the lock is not already installed, you can tap Next and follow the in-app installation instructions.
- If you’ve already installed your Wyze Palm Lock, tap Skip.
- Now let’s connect your lock to your Wi-Fi network. Tap Next to proceed with setup.
- Do not install the battery cover until after you finish setup and pairing.
- Press and hold the RESET button on the lock for 8 seconds.
- The status light will pulse red.
- In the app, check the box next to I heard, “Ready to connect”, then tap Next.
- If Bluetooth® hasn’t already been enabled, you’ll be prompted to allow Bluetooth® and location access. Tap Next.
- If Bluetooth® and location access have already been enabled, it will skip to the next step.
- The app will automatically begin searching for and pairing to your Wyze Palm Lock.
- Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
- Tap the icon in the password field to display the password to ensure it was entered correctly.
- Your device will finish pairing. Then it is time to name your Wyze Palm Lock using the text field, or by choosing one of the preset suggestions, then tap Finish.
- Setup complete! Now let’s customize and calibrate your Wyze Palm Lock. Tap Next.
Continue onwards to our Wyze Palm Lock Calibration Guide.
