Problem
Wyze Palm Lock does not unlock with your access code, or you can’t set up your access code.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that Wyze Palm Lock’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the lock, please move forward with updating it.
- Make sure there is no debris on the keypad display.
- Gently wipe it with a soft, dry cloth.
- Ensure there is nothing interfering with the keypad while the code is being entered, such as:
- Excess oil, water, or debris on the fingers.
- Gloves, paint, or large jewelry/accessories.
- Any items being held, such as keys, that may be hitting the display.
- Any stickers or labels that came on the device.
- Check that enough pressure is being applied to the keypad display.
- The keypad relies on pressure to activate, so dry skin or gloves should not impact the use of the keypad.
- Verify that the lock is awake before attempting to enter the code.
- Tap the keypad display to ensure it is awake.
- The keypad will light up when awake.
- If it does not turn on after tapping, refer to My Wyze Palm Lock won’t turn on.
- Note: By default, the lock will auto-wake when a person is 3-5 feet away. If it does not auto-wake, check whether the device is using a battery-saving mode by going to the lock’s settings > Battery Management.
- Check if there is a sound after each press on the keypad.
- By default, the lock will emit a beep sound when the keypad is pressed. This can be disabled by going to the lock’s settings > Volume.
- Check the number of times the code was unsuccessful.
Failed Entry Lockout is enabled by default, and if an incorrect code is entered 5 times in a row, the access code functionality will be disabled for 5 minutes.
- If the lockout period is active, use an alternate access method (key, palm, app, etc.) or wait until the lockout period is over.
- This feature can be disabled by going to the lock’s settings > Failed Entry Lockout.
- Reset the access code associated with the user profile.
- In the lock’s settings, tap Access and Sharing.
- Select the correct user profile.
- Next to Access Code, tap Reset, then follow the in-app instructions to create a new one.
- The code must be 4-8 digits long.
- It must include at least two unique numbers. (For example, 5555 will not be accepted.)
- It cannot contain consecutive sequences, e.g., 1234.
- Once created, the code will not be visible in the app but can be reset at any time.
- For shared users, reach out to the account/device owner to verify your permission level.
- Shared user access can be set to Always, Recurring, or Custom.
- Check if the code being used is a One-Time Code.
- This can be checked in the lock’s settings > One-Time Code.
- This code can only be used once before the expiration date.
- The expiration date is set to 4 hours after the code’s creation, but can be set to a custom date.
- Note: This code can only be managed or seen in the app by the device/account owner.
- Restart Wyze Palm Lock.
- Navigate to the device’s settings > Restart Device > Restart.
- Factory reset Wyze Palm Lock.
- Remove the cover on the interior assembly by pressing in and up on the top portion of the interior assembly.
- Press and hold the reset button for 8 seconds until the status light begins pulsing red.
- Once the status light starts pulsing red, set up the lock as new.
