Problem
Your Wyze Palm Lock is sending you too many or too few notifications or alarms.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that Wyze Palm Lock’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the lock, please move forward with updating it.
- If receiving too few notifications, ensure that Notifications are set correctly.
- For Wyze Palm Lock:
- In the lock’s settings, tap Notifications.
- Toggle Device Notifications off/on.
- The toggle will be green when enabled.
- Under Notify Me When, select the desired notifications.
- Door is Locked – Receive a notification when the door is locked via any method (app, palm, key, Auto-Lock, etc.).
- Door is Unlocked – Receive a notification when the door is unlocked via any method (app, palm, key, etc.).
Door is Open – Receive a notification when the door is opened.
- If Wyze app notifications are silenced or disabled in the phone/tablet settings, but this setting is enabled, the local alarm will still occur.
For More Than – Receive a notification when the door is left open for longer than a set amount of time between 15 seconds and 59 minutes.
- This option is only available when Door is Open is enabled.
- Note: Even if Device Notifications are disabled, the following critical warning notifications cannot be turned off.
- Lock jammed
- Failed to lock
- Failed to unlock
- Calibration warning
- Device offline
- Battery low warning
- Failed entry lockout
- For the Wyze app:
- Navigate to the Home tab of the Wyze app.
- Tap Account > Notifications > Push Notifications.
- Toggle on Push Notifications.
- For the mobile device:
- Navigate to the device’s settings.
- Enable notifications for the Wyze app.
- If receiving too many notifications, disable the above options as desired.
- Adjust the Volume settings.
- In the lock’s settings, tap Volume.
- Under Status and Operation, adjust the slider bar to the desired volume.
- Under Alarm, adjust the slide bar to the desired volume.
- For mandatory alarms, they can be silenced (but not disabled) by lowering the volume to 0, but we do not recommend it.
- Verify that there are no Automations set up that could be causing interference.
- Navigate to the Home tab of the Wyze app, tap Automations.
- Note: We recommend deleting any Automations and then adding them back one by one while testing.
- Restart Wyze Palm Lock.
- Navigate to the device’s settings > Restart Device > Restart.
- Factory reset Wyze Palm Lock.
- Remove the cover on the interior assembly by pressing in and up on the top portion of the interior assembly.
- Press and hold the reset button for 8 seconds until the status light begins pulsing red.
- Once the status light starts pulsing red, set up the lock as new.
