Problem
Your Wyze Palm Lock is not automatically locking when the door is shut, or is not locking for a certain amount of time after the door is shut.
Troubleshooting
- Confirm that the Wyze app is up to date.
- In your Wyze app, navigate to the Account tab > tap About.
- Your current app version will be listed beneath the Wyze logo.
- Compare your app version to the latest app version listed on our Release Notes & Firmware page.
- If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
- If possible, check that Wyze Palm Lock’s firmware is up to date.
- You can check this by going to the Account tab > Firmware Update.
- If there is an update available for the lock, please move forward with updating it.
- Ensure that Bluetooth® is enabled for the Wyze app in the phone/tablet settings.
- Toggle Bluetooth® off/on.
- Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
- Make sure that it is set to Always or While Using the App.
- For iOS users, make sure that Precise Location is turned on.
- Ensure Wyze Palm Lock has good signal strength.
- You can check this in the Wyze app by going to the lock’s settings > Device Info > Signal Strength.
- If it has 2 bars or less, try moving the router closer to the lock.
- Ensure that the Auto-Lock settings are set correctly.
- In the lock’s settings, tap Auto-Lock.
- Toggle Auto-Lock off/on.
- The toggle will be green when enabled.
- Select Immediately while testing.
- Once this option is determined to be working as expected, switch to After a Delay, if desired.
- Note: If the door is opened before the timer is complete, the timer will reset once the door is closed.
- Verify that there are no Automations set up that could be causing interference.
- Navigate to the Home tab of the Wyze app, tap Automations.
- Note: We recommend deleting any Automations and then adding them back one by one while testing.
- Recalibrate the lock.
- In the lock’s settings, tap Calibration.
- Follow the in-app steps to recalibrate the lock.
- Be sure to proceed between steps only as directed by the lock’s voice prompts.
- If there are issues recalibrating the lock, refer to My Wyze Palm Lock fails to calibrate.
- Restart Wyze Palm Lock.
- Navigate to the device’s settings > Restart Device > Restart.
- Factory reset Wyze Palm Lock.
- Remove the cover on the interior assembly by pressing in and up on the top portion of the interior assembly.
- Press and hold the reset button for 8 seconds until the status light begins pulsing red.
- Once the status light starts pulsing red, set up the lock as new.
